I got a 2006 f250 that will start up and run for about 10 seconds then dies no codes icp and ipr are doing what they should when vehicle dies its as though the key is turned off. Fuel rail pump, high pressure pump low pressure pump have all been replaced
I would do a bubble test to see if an injector is allowing combustion gas to interfere w/ fuel flow.
· Vendor
FICM Voltage?
