What size dana is on the rear of a 2006 F-350? 60 or 70?
The 2005-2007 F350 SRW has a Visteon Full Floating 10.5" & a Dana 60 9.75" up Front.
Specs:
Model F-350 SRW (Standard and Limited-Slip)
Visteon
Max. Rating @ Ground (lbs.)
7280
Type Full-Floating
Driveline Attachment
Circular Flange
Housing
Type Cast Center
Cover Attachment Bolted
Section Tube Dia. (in.) 3.50
Synthetic Lubricant Capacity (pt.)
7.0
Spring Centers (in.) 45.0
Wheel Bearings Type Tapered Roller
Gears
Type Hypoid
Material Alloy Steel
Ring Gear Pitch Dia. (in.) 10.50
Pinion Mounting Overhung
Differential Type (1)
Axle Shaft
Spline Minor Dia. (in.) 1.50
Spline Major Dia. (in.) 1.57
No. of Splines (Hub End) 35
Jeremiah
