2006 Ford F-250 6.0 Powerstroke 5R110
I am having 2 transmission codes come up
P0766 Shift Solenoid "D" Performance/Stuck Off
P2703 Transmission Friction Element "D" Apply Time Range/Performance
I did a drain and fill, replaced both trans filters and the Shift Solenoid D with a brand new one, after doing this I am still having the same 2 codes come up and it will go into limp mode, also when I had parked it originally it would not shift out of any of the forward gears. At times when you shift into Drive it will not shift and will slam into gear, and will do the same into reverse. I am thinking that the Tranny needs rebuilt, but just want to confirm my thoughts.
