It feels like someone is pushing the gas pedal I can’t not stop the truck I almost crash in to trailer
A scan tool will be needed to see what the engine is doing and why - you could see if the accelerator is the cause, or look at injection control pressure and regulator values to see if there is an ICP fault. Also, a sticking torque converter clutch can also cause the symptom you describe. And for the sake of not excluding it, check to be sure you do not have a floor mat issue causing the accelerator pedal to not return.
