So this all started out with a misfire in cylinder 8. Which I took to a diesel mechanic who told me I needed injectors. $5,000 later I still have a miss and a diesel mechanic telling me it must just be the motor, give him $13,000 and he will replace it . I did not do this the miss led to a Knocking, which led to a popping in the air box. The popping led to a very loud metallic knock which led me to the garage where I proceeded to tear it down. Upon tearing down I discovered a bent pushrod crushed lifter and a broken piston on the bottom side. This led to a new connecting rod, New wrist pin, one push rod, a new lifter and hopes this will solve the problem.
Put it back together yesterday, started it today to find it still Knocks. Pulled everything apart so I could see the valve train ran the motor everything appears to be fine but a definite knock from the driver side of the motor possibly cylinder 8 still. Went ahead and pulled everything apart pulled the head back off everything looks normal butt I now noticed the valve train on cylinder 8 is blacker than the rest.
I am now looking at the old piston and do see evidence of where the valves have hit the piston or left indentation where the valve is located, that I do not see on the rest of the Pistons.
Could the valve train or these valves be the reason for this whole problem?
The blackening on the valves that I am describing has always been there, but didn't suspect valves only because the bent push rod crushed lifter and broken piston seemed an obvious culprit
