ac only blows if I under the glove box with a stick then the ac starts blowing. Is it the blower motor of is it a flap of some kind ?
I'm guessing that you mean you hit under the glove box to make the ac work. Next time, before you hit it, listen closely to see if the fan is running. If it is not, then you probably have either a bad wire connection OR a bad blower. If you can hear it, the blend door is sticking. That can be a loose vacuum line or a buildup of dirt.
