2008 F-350 Superduty XLT with the 6.4. Driving down the road hit a bump and the instrument cluster went to zeros on everything and then started showing "check brake system, fuel pump picture, and traction control warnings" i pulled over and shut it off then started it again and after about 10 seconds it did it again. I pulled over again and then it wouldn't start again as the anti-theft light flashes very rapidly. I believe it is my BCM but I would like to verify before replacing it.
Well I would check all the electrical connections and look closely at the battery cables. Most of the time this stuff can be the ground cable. Make sure the frame ground is clean just liked the battery
