Hi guys I am new to this forum and in need of some help. Thank you too anyone who does help. My truck is acting really strange and idk what to do I recently had a code for the EBPS I cleaned it and my check engine light went away. Anyway the current issue is the truck battery drains really fast. I jump the truck and it will run on its own for a while then I go to start it again and it try's to start and then the batteries just die. I can hear a weird clicking noise near the radio and the CD player says cd error. the battery light on the dash is also on along with another light that is a car with a lock on it. Once I get the truck started it idles pretty well and then it starts to stumble a little bit and then will go back to normal. Every now and then I hear a strange buzz coming out of the egr valve also. White smoke is pouring out of the exhaust. The coolant has not drained at all. The pictures attached are with the truck hooked up to a jeep with jumper cables in case you are wondering why the batteries say 13.6 volts. I have no idea what is wrong with the truck I've only had it for 3 months I bought it used with 183,000 miles and I probably drove 800 completely fine. There is also some type of oil leak on the driver side when I go under the truck I rub my finger on the engine and find oil on it it goes pretty high up. Please any help would be much appreciated once again thanks to anyone who helps me out!!!-
Seth
Seth
