2008 F350, low miles 62K on the clock. I have started having a pulsing in the wheel on long curves. It has gradually gotten worse. Power Steering fluid level is normal. Any thoughts?
Sounds like a tire. Possibly a slipped belt in the tire or low air pressure. That's generally the first sign is a wobble in the wheel more pronounced on curves.
Hi guys, new to the site. I had the same problem. It felt like a dead spot in the steering. Do you notice your brake pedal locking up as well at the same time. The power steering (ATF) fluid became contaminated somehow. It has something to do with the hydroboost system.
Reviving this old thread, as my 08 F350 4x4 has the same problem. Tires pull the wheel back and forth in the middle of long turns at highway speeds, both left and right. New tires did not fix the issue and it does it whether braking or not. Truck has 168,000 miles and I'm sure front suspension/steering components are worn, but steering seems tight otherwise. Wondering if anyone has a specific fix for this issue.
Good evening everyone... working on a 08 F250 that has a couple of transmission problems. Trans slipping and no reverse
The codes i have are p0766 and p2703. I ordered a new filter (atp b359) and oil Mercon SP.anyone ever had same problems
1. While streaming live data... when I select reverse...
I have a 2010 f350 lariat and one mirror was ripped off the truck. it has been replaced and now none fold.
The mirrors are power everything.
Both mirrors telescope and glass tilts but no fold.
I put a new mirror fold relay in behind light controls under drivers side dash but it did not fix it...
Installed New battery’s in Aug. Last Tuesday Battery Light came on. I checked the charging system it wasn’t charging I replaced the alternator. It is charging at 14.3 volts now. When I started the truck the light turned off then after about 15 sec. it came back on. Check codes it had P0620 and...
2008 F-450 Super Duty Lariat. We just purchased the truck and GPS won't find truck. Shows it about 600 miles away.
We tried resetting the GPS and that did not solve it. Any other ways to fix the gps? Is there a chip that needs replacing or is the whole radio/nav system have to be replaced?
Any...
I replaced my starter on my ‘08 F 250 . It worked eight or nine times and it went right back to not starting just getting a click at the starter and then you can hear it release. The batteries are from Ford and 10 days old, my alternator was replaced One year ago with true blue Ford which the...
A forum community dedicated to all Ford PowerStroke Diesel owners and enthusiasts. Come join the discussion about PowerStroke performance, modifications, troubleshooting, towing capacity, maintenance, and more!
