I am having same problems any ideasHey Dillon, did you ever get this issue resolved? I am having the same issue with mine and I am really wanting to lay the blame on the mini max I used.
I think it is from the mini max trying to trick the computer into having max fuel rail pressure all the time. I’m trying to get a different SCT tune on mine to see if that can make it happy. But my pickup is still parked in the shop unusable right now.I am having same problems any ideas
Anyone have any luck solving their problems? I have a 15 6.7 I’ve spent entirely to much money on at the Ford dealership and it still has embarrassing low power. It’s had all the weight reduction performed. Sct livewire with custom tunes. Ford replaced more parts than I can list on here. P228E is what it went to the dealership for. The code is still present along with a new one when I got it back from Ford. P2455. I’m lost. My first diesel truck and potentially my last if it continues to $100 me to death. I’m over $5k in repairs and have a $50k yard ornament that’s worthless and not paid for. Any advice. Thanks. Shane.I think it is from the mini max trying to trick the computer into having max fuel rail pressure all the time. I’m trying to get a different SCT tune on mine to see if that can make it happy. But my pickup is still parked in the shop unusable right now.
You get this figured out man? Having the same issue with my ‘15Anyone have any luck solving their problems? I have a 15 6.7 I’ve spent entirely to much money on at the Ford dealership and it still has embarrassing low power. It’s had all the weight reduction performed. Sct livewire with custom tunes. Ford replaced more parts than I can list on here. P228E is what it went to the dealership for. The code is still present along with a new one when I got it back from Ford. P2455. I’m lost. My first diesel truck and potentially my last if it continues to $100 me to death. I’m over $5k in repairs and have a $50k yard ornament that’s worthless and not paid for. Any advice. Thanks. Shane.
No luck yet. Mechanic traced every wire and sensor. All checked ok. All have been replaced by ford. Lift pump pressure is low. Psi is High 40’s to Low 50s. Fass system is on the way. Hope to have it installed within the next 2 weeks. I’ll update.You get this figured out man? Having the same issue with my ‘15
Anyone get this sorted yet? I have my truck at the dealer for the 3rd time with this exact issue. it hard starts, throws codes, stalls when I put it in gear, get it to drive down the road and all codes clear (except the permanent codes: High pressure fuel rail and so on) Over $3k dumped in the last 4 months trying to sort this out. My truck is all stock (as far as I know) and hasn't been deleted. Dealer called today and said the truck is running fine and they can't get it to act up.... Any help would be wonderfulNo luck yet. Mechanic traced every wire and sensor. All checked ok. All have been replaced by ford. Lift pump pressure is low. Psi is High 40’s to Low 50s. Fass system is on the way. Hope to have it installed within the next 2 weeks. I’ll update.
