Hello all....I'm new to this site because I have a 2011 Ford F550 with 57,620 miles and the 6.7 powerstroke diesel engine. I've been told by the service people at the Ford dealer there is no compression coming from cylinder 5 in the engine. The warranty is done because of the year i purchased truck (Sept 2010), but well under the 100,000 miles. I have filed a claim with Ford, but wanted to know if anyone has similar issues or if this could be something other than catastrophic engine failure?
Most common issue on a 2011 6.7L with low compression is due to a dropped valve. The valve typically drops in pie-shaped pieces and should not affect vehicles built on or after 29 March 2012. When this occurs, a glow plug DTC is the most common to set (P067x) where X indicates the cylinder number (1-8). Remove the number 5 glow plug and inspect the tip. If the tip is cracked, damaged or missing, a dropped valve would be the most likely cause and long block replacement will most likely be necessary. Ford has a TSB regarding this issue, which is for direct long block replacement (when under warranty) due to low compression, a glow plug DTC and a damaged glow plug tip.
There are not many "non-catastrophic" issues that can cause a loss of compression from a cylinder unless recent repairs have been completed. If the injector or glow plug is loose, compression could escape, though this is far from being "common" especially on this model year 6.7L.
You may be able to speak with the dealership for assistance with the repair, or contact Ford CRC (Customer Relationship Center) regarding CLP (Customer Loyalty Program) if you are a long-time Ford owner. They may be able to assist with the repair some. Best of luck!!
Yes I have a 2011 f350 with the 6.7turbo diesel NY truck I was pulling a tractor made right foing up hill and I just heard noise like a down shifting noise. Pulled over brought it home try turning over it wanted to but just couldn't. A bunch of DEF codes came and a P2291 .hmm mechanic said could be several things.Took it to a shop took a compression test and #5 was very low mechanic said I need a new block ,charge $11,500.
