I have a strange issue going on - passenger side tail light doest not work - brake light and blinker work great. any advice would be appreciated........
I flip-flopped the lights and the tail light works when its on the driver side.... so it must be something in the wiring I assume?
Is there a fuse for this?
If you've swapped the bulbs and confirmed they're good, check for voltage in the passenger side socket. Also check the ground contact to be sure it's got good continuity to ground. Sounds like you might have a wiring issue, which you'll need to check back to the splice with the feed wire to the driver's side. I believe the only fuse would be on the power side of the headlight switch, which would be common to both lights.
