Hello, i spent some time on the internet and on this forum and on another similar one to try to find information about how to grease and lube a 2012 f250 6.7L power stroke.
Ford maintenance recommends lubricating all non-sealed steering linkage, ball joints, suspension joints, half and drive and axle shafts and u joints but doesn't provide any details.
i found a video on tube that says that the only grease fittings available are in the front wheel u-joints. i was able to find those 2 and greased it up but it seams that all others linkage are sealed. is it true?
Thanks,
2016 F250 here
Yup only on the front two.
I have used a zert to hypodermic needle attachment for grease gun and pushed some grease in the boots for tie rods etc. They last longer if you add lube
When I have any of them replaced it will be jobber aftermarkets with grease fittings
RoadrunnerII
Sent from my Moto G Play using Tapatalk
