I have a 2014 f250 super duty with a 6.7 liter diesel. About 6 months ago one of the exhaust manifolds separated from the its head and had to be replaced. When this happened the engine would make a horrible squealing noise, like a bearing of some kind. The truck had a little over 100,000 miles on it (just out of warranty). I took the truck to the Ford dealership where it had all of it’s work done since I got it. To fix the problem the dealership told me that they had to lift the cab off the frame to get to the exhaust manifolds. Both manifolds were replaced to prevent the problem from reoccurring. Took 2 weeks for them to do the job. While they were performing the repairs a piece of exhaust gasket fell into one of the cylinders and lodged itself between the piston and the cylinder wall requiring the cylinder head to be removed to get it out. When I finally got the truck back the squeal was still there but not as pronounced. I took it back to the dealership and after 2 more weeks they said they couldn’t find anything wrong and that the truck was fine. I took the truck to a local diesel mechanic and he found that the turbo charger had a cracked housing and needed to be replaced. After the turbo was replaced the noise was gone but the new turbo is very loud and the truck has developed a lugging/shuddering problem. While cruising between 40-50 miles an hour in 4th or 5th gear and rpm around 1100 the engine will start to shudder and the whole truck will start to shake kind of like driving over washboards. The problem will also happen in 5th gear at about 60-65 miles an hour and 1300rpm. Letting off of the accelerator or getting on the accelerator will make the shudder disappear. It is way more pronounced going uphill or when towing my work trailer. The trailer weighs about 3 tons. This never occurred until the turbo charger was replaced. Sorry for the long story but I wanted to let you know the whole story. Any thoughts on this? Thanks
