There isn't one on the 6.7L. To purge air from the system after fuel filter replacement or fuel system repairs cycle the ignition from off to run without starting for 30 seconds 6 times. Then crank. If the engine does not start - repeat as necessary.
If it still doesn't start check the filtewr under the truck to make sure the canister is tight. Just be careful you don't brake it. There is a stop so don't force it past that.
