The weather has been cooperative lately and so I decided to install my front axle Mag-Hytec cover. The truck has a little over 9,000 miles on it, but only about 500 on the front axle (4WD). Nothing unexpected was found and the oil was only slightly gray. Five quarts of Amsoil 75W-110 were installed (which is two more than the stock cover would allow). The wear pattern on the ring gear looks fine indicating that Ford did a good job of setting up the axle. This is a Dana Super 60 9.75" differential with a 3.55 ratio. The next project is to install the Amsoil Bypass system and the oil pressure, rear axle and front axle temperature gauges.
Enjoy!
Enjoy!
