Im looking for a set of 2017+ f250 Rear 2 in spring blocks, anybody have any or know who does would be great.Thanks
Question is why do you want to put these on your truck? Do you just want the back to sit higher? You can go to the dealer and look at a truck on the lot with them. Take the vin to the parts guy and he can order them for you. Only need the last 7 numbers I think.
Do remember to replace the spring u-bolts and nuts when performing this procedure. Once loosened Super Duty spring u-bolts should never be reused.
Do you know if they used the same blocks as earlier models or did they change them with the new body?Thanks
Not without having a parts counterman look them up. Pretty much everything is new for 2017 so it is likely that they are different but as I said... without looking up the part numbers of comparing them side by side....
