Short version- Father in Law mangled the drivers door on his 2020 f-250 with the key pad. I can pick up a replacement at a wrecking yard for less than $1000 and not make an insurance claim. With the exception of the lock cylinder, will the keypad work once plugged in or does it have to be programmed? Any advice on removing the lock cylinder to put in the new door?
Thanks in advance for your response.
Jay
The key pad is hard wired and no programming is required.
