I attached the 2017 Customer Access Wiring Guide bulletin. Scroll through to find the Upfitter Switches - this will be helpful if you do not have an accurate wiring diagram.I'm trying to hook up an auxiliary light on my truck and the upfitter switches don't seem to work. Anybody have any help?
Morristownford doctor where in nj are you located
The file attached has the wiring and fuse and relay information. Save the file and print it out so you have it. However, it sounds like you shorted the circuit to ground or overloaded the circuit - it's a 25 amp fuse so I imagine it was possibly a short while you were working. The relay box is actually the one pictured on the Youtube video above. For switch #1 it's fuse #10 - 25 Amp. The fuses are unique, and you will likely need to visit the dealer to get one or search the Internet - you will save money doing so.For now you can borrow a fuse from one of the unused upfitter switches.Thanks, but I watched this video before I began. I thought it looked pretty simple so I tried. I had power out to switch #1 momentarily and then nothing. Is there a fuse that may have blown? I'm not a mechanic, but understand wiring pretty well usually. Thanks BR
