Have a 2022 F650 with 6r140 transmission . Tech has located an up fitter harness at drivers kick under dash. The Parker tech support says install manual color codes are incorrect. Is the the correct blunt cut wire harness and if so are the description correct? Thanks for any help you can provide.
