Here is my situation....I'm going to be putting on a 2.5" leveling kit and f-350 blocks on my 04 King Ranch, but I am having trouble finding a tire that will fit on my 18" stock wheels. I have found that for a leveling kit a 33x12.50 is the largest you can go without trimming, but the only true 33x12.50 I can find is the Toyo Open Country M/T. All I can find in a 33 is 13+ wide which is too much for the factory wheel. I want to run either Mickey Thompson ATZ or Procomp Extreme AT but neither make the size I need. Mickey Thompson makes a 275/70r18 in the ATZ which is 33.3x11.00, but will that look too skinny?? Is there any way I can squeeze in 35x12.50 with just a leveling kit, or will it look too stuffed?? Pictures and/or comments would greatly be appreciated. Thanks.
Thanks for the reply, they look great. Looking at them online I didn't really care for them, but when I saw them in your pics I quickly changed my mind. A friend of mine also just got them on his 06 and I saw them for the first time today. The size looks perfect on the stock 18" wheel. I wish other companies would come out with this size. Is anyone running these tires on a 99-04 truck? Any troubles hitting on the leaf springs?
On my 2000 F-250 I had 35x12.50 with a leveling kit. No rubbing unless I REALLY had the suspension articulating. The backspacing of the wheels would also play a factor in whether the tires would rub on the front springs or not. I don't remember what BS the 16.5x9.75 Weld Typhoons had that were on my old truck. Hope this helps.
35s dont rub my truck anywhere, and i put them on there stock.
I also have the 18" wheels . I went with the toyo open coutry at in 275/70 and really like them . 30,000 miles so far and their in good shape . you can also get them in a 285/75 18" . those are about 35' and 12" wide .here's a link TOYO Open Country AT @ Tire Deals 4 Less .
