My Scheduled Maintenance Guide say every 30,000 miles you should "Inspect/adjust 4x2 wheel bearings for end play."
It seems sorta silly to go to that much trouble and not repack the bearings while you're in there. /ubbthreads/images/graemlins/shrug.gif But nowhere does it mention the actual repacking of the wheel bearings.
However, my dealer is a little more plain-spoken. His scheduled maintenance guide for PSDs says every 35,000 miles to "Inspect and re-pack front wheel bearings 2WD. $60.75".
Here are most of the words from the workshop manual:
2000 F-Super Duty/Excursion/Motorhome Chassis Workshop Manual
SECTION 204-01A: Front Suspension — <font color="red">4x2 </font>
REMOVAL AND INSTALLATION
Wheel Bearing and Hub —F250, F350, Excursion
Removal
Raise and support the vehicle.
Remove the front wheel and tire assemblies.
Remove the front disc brake caliper and rotor, and position the caliper out of the way.
Remove the hub cap from the hub assembly.
Remove the cotter pin, adjusting nut and flatwasher.
NOTE: Inspect the condition of the spindle and nut threads to ensure a free turning nut when reassembling.
Remove the outer bearing cone and roller assembly, and pull the hub assembly from the spindle.
Using care not to damage the bearing cage, use a suitable slide hammer and bearing seal remover to remove the inner bearing cone and bearing seal.
Installation
CAUTION: Do not spin the bearing dry with compressed air.
NOTE: Remove all traces of lubricant from the bearings, hub and axle spindle. Inspect bearings and bearing cups for pitting, spalling or unusual wear. If either bearings or bearing cups are worn or damaged, replace both bearings and bearing cups.
NOTE: It is recommended that bearings and bearing cups be replaced in sets. If cups are worn or damaged, install the inner and outer bearing cups in the hub with an appropriate bearing cup driver tool. Check for proper seating of new bearing cups by trying to insert a 0.38-mm (0.0015-inch) feeler gauge between the bottom face of the cup and wheel hub seat. You should not be able to insert the feeler gauge.
Remove all burrs, nicks or scratches from the shoulder of the spindle and seal bore in the hub with emery cloth.
Pack the inside of the hub with lithium-base wheel bearing grease such as Motorcraft Premium Long-Life Grease XG-1-C or -K or equivalent meeting Ford specification ESA-M1C75-B. Fill the hub until the grease is flush with the inside diameters of both bearing cups.
Pack the bearing cone and roller assemblies with wheel bearing grease. Use a bearing packer for this operation. If a packer is not available, work as much lubricant as possible between the rollers and cages.
CAUTION: Keep the hub centered on the spindle to prevent damage to the grease seal or spindle threads.
Place the inner bearing cone and roller assembly in the inner cup and install the wheel bearing hub seal, using a suitable seal replacer. Make sure seal is fully seated and lubricated.
Install the hub assembly.
Install the outer bearing cone and roller assembly and the flatwasher on the spindle and install the adjusting nut;
Wheel Bearing Adjustment —F-250, F-350, F-450, F-550
CAUTION: Wheel seals on the front axles must be replaced any time the axle lubricants are changed from factory-installed mineral lube to synthetic lube or vice versa.
CAUTION: If bearings are adjusted too tightly, they will overheat and wear rapidly. An adjustment that is excessively loose can cause pounding and contribute to uneven tire wear, steering difficulties and inefficient brakes. Check bearing adjustment at regular inspection intervals. New wheel seals must be installed when the hub is removed. A damaged or worn seal can permit bearing lubricant to reach the brake linings, resulting in ineffective brake operation and necessitating premature replacement of linings. To check the wheel bearing adjustment, raise the front of the vehicle. Grasp the tire at the sides, and alternately push inward and pull outward on the tire. If any looseness is felt, adjust the front wheel bearings as follows.
While rotating the wheel, tighten the adjusting nut to 21 lb/ft to seat the bearings.
Back off the adjusting nut until loose.
While rotating the wheel, tighten the adjusting nut 120 to 180 degrees. Torque required to rotate the hub should be 2 Nm (18 lb-in).
Install the castellated nut and insert a new cotter pin.
Install the hub cap.
Install the front disc brake caliper and rotor. For additional information, refer to Section 206-03 .
Install the front wheel and tire assemblies.
Lower the vehicle.
