So im currently running stock rims on my 2003 F250 with 285/75/r16 MTs with no rubbing at all. I do have a 2.5" leveing kit on the truck as well.
I wanted to run 35x12.5r16 with the rims linked in this thread (Cragar Soft 8s) but i'm not sure if I need any negative offset or a certain back spacing in order to run 35s.
Right now the 285/75/r16 is basically a 33" and doesnt rub at all. My worry is it rubbing the leaf springs. I know it's tough to say without physically seeing the truck in person but I was hoping someone had a similar experience and could shed some light.
These are the rims I was thinking about getting.
https://www.summitracing.com/parts/crr-3977881/recommendedparts
Thanks.
Keep the stock wheels,,,,, the ones in the link --- not so handsome......
You will not fit 35s with 2.5" of lift. I ran 295s on 16 x 10 with 4.5" offset and barely, barley cleared at full wheel cut on flat ground.
Note, this truck had stock X code springs and 2 add A lefts on 02' F350 CCLB.
