From what the ordering guide says, the brakes are still larger on the 450's. Some have said the calipers are still the same as the 350's to fit the 17" rims though. Question is, and I'm not very smart with vehicles, but if the calipers are the same size you're not getting any additional braking if just the rotor is larger - correct? Because you would still only have the same surface area braking as the 350. I'm still stuck on the "whats the difference between the 350 and 450" discussion because i'm ready to order. So if the brakes are the same, it really does just leave the slightly wider front end and the 430 gears which is a hard justification for $4,000. Is it really only these two differences then? Thanks for all comments, much appreciated.
