post some pics of 99-04s with a 4inch lift....
I am trying to see if I could clear 36/14.50s on 16x10s with a 4inch.
Yes bubba you could clear them, might need to trim some plasic on the inner fender up front. Its your tow rig..Level it with some 35s and get a nice set of shocks.
I have a 99 xcab long bed w/35's. I could easily run 36's in the rear, even 37's its the front that would cause some issues. Over the past 7 years the weight of the 7.3 plus a more than generous share of trails has made the front sag about half an inch (ProComp all spring lift). If I re-arched the front and added an inch or so I would probably be able to run 37's. Long story short it depends on application (quality) and use, but I would think you could find a 4" kit that would suffice.
