1 - 10 of 10 Posts
I have a 2001 Ford F250 4x4.7.3 Stock. I am having a issue were it has a occasional slip in 2nd, not all the time but becoming more often, do I need to rebuild the transmission or is there something else i can check
You need to rebuild it. The 2001 diesels had a new type one way clutch that was prone to failure. You have the symptoms.
Reactions: Andrew Hubert
The dreaded mechanical diode.
Make sure the convert it to the other style.
Don't have them put in another new mech diode
Discussion Starter #4
Can I pull the guts out of a 4r100 off a 5.4 and put them all in my 7.3 4r100???
You can't even get a new mechanical diode for this trans.
Yes, you can. It will all fit. It won't last long at all, though. The 5.4L parts are nowhere near strong enough to last behind a 7.3L.
Discussion Starter #6
Will the guts out a E40d work inside the 4r100????
Yes, they should. I've never heard of anyone doing this, usually it's putting the guts of a 4R100 into an E4OD, but I don't know of any reason it shouldn't work.
Most of the internals are the same, but not all. There are some sensors on the 4R100 that aren't on the E4OD, so it would follow that the tone rings or whatever the sensor feeds off of wouldn't be there in the earlier transmission. PLUS, a lot of components in the E4OD were aluminum that were upgraded to steel in the later 4R100s. I wouldn't want to go backwards on reliability by putting in the weaker components.
Discussion Starter #9
Thankyou guys for all of your help,
Oops! I forgot about that. E4OD internals will NOT work in a 4R100.
Yep, that's true, too.
1 - 10 of 10 Posts
