swap solenoid pack, tr sensor and lever, convert pwm lock up in pump to on off, tailhousing if 2wd, cooler fittings or use 3/8 lines. Thats it.
Ditto what Richter69 said....I did it. In fact I didn't even do the pump mod...based on what I heard from somebody that had done a couple of these swaps. You may have to fab a couple of plugs for some sensors that the E4OD doesn't have....unless the donor trans has them installed, then your good.
Which leads to another question for Richter....I'll be swapping engines here soon, so I have a chance to to the pump mods that come with the Transgo Kit....not the Tugger, the HD-2 I think it's called.
What say you Mr. Tranny man?
Dan
