1 - 9 of 9 Posts
Recently had the transmission rebuild, picked it up two weeks ago tomorrow. (maybe 300 miles on it)
The shop was highly recommended and does a lot of fleet work. I called them today to schedule a two week follow up (its stated on the work order I must do) and to retrieve my two year warranty.
I set an appointment for Friday morning and asked if the could do a test drive with there snap on scan tool. They had no problem with me coming in Friday morning but wanted to know why I wanted them to scan it.
I let them know the truck is not holding fist gear and slamming into second premature.
I was told that sounds like a computer issue...
Basically i took the truck in to have the tranny fixed. It worked fine for over a week and went back to the same issues I was having prior to spending $$$. Does this sound right?
If they are correct and the computer is the issue is it as simple as a new flash? Or do i need a new PCM? I cant see any codes (pulling from a sct tuner) ,no cel, no flashing od light and the fluid is clean and full.
Thank you for any info and advice,
JPC
It's very rarely the computer. It usually is bad info from one or more of the sensors. Someone that has a good scan tool and knows what to look for can find the problem.
Thank you Mark,
I will Post what they find and the the snap on model scan tool they are using.
Thank you again.
JPC
Why can't it be the computer ??
I had my DP Tuner doing the same thing when I first installed the chip on the computer. I had the shifting program/profile on the chip redone to eliminate the hard shifts.
Does your new trans shift differently when you remove your chip ??
Like Mark said it is likely bad info from one of your sensors. The last time I had a similar issues (and was really pissed due to the fact that my trans has been replaced somewhat recently) it turned out to be a bad ICP! No codes, but if the motor isn't powering properly even if unnoticeable, the trans can do funny things...
Ok today as I was going to park my 2000 F350 7.3L with an automatic transmission I noticed a trail of fluid coming from my truck and when I stepped out I noticed it was coming from where my engine and transmission came together. Also after I parked it really started pouring out. What could possibly be my problem? (Worst and best case) Also I checked my transmission fluid level after noticing the fluid leak and barely any was showing up on my dipstick.
Likely your front seal. They will leak when hot. Were you doing anything to heat the transmission up?
Best case: The torque converter hub seal (also called the front seal) is worn and leaking.
Worst case: The torque converter has developed a crack (very rare, but possible.)
1 - 9 of 9 Posts
