Show of hands...how many here that don't drive your truck everyday have wet pan syndrome?
Under the truck the other day and I had to wipe down pretty much every pan bolt and the surface of the pan from 'seepage'?
I'm told it's normal as fluid leaks down out of the converter to above the pan level and there are many seals that get covered by fluid and the longer the truck sits, the more likely seepage will occur...not just from the pan gasket.
