1 - 14 of 14 Posts
Trans has 180k, good maintance, getting a shudder occasionally when accelerating mostly while pulling 6500lb trailer, other than complete failure when do you consider a rebuilt trans? Lifespan of transmission is all over board dont want to cut it short if it will go 200k +, but dont want to be stranded. Not sure if normal failures are slow degredation or 1 day just gone
I would take the driveshaft out and inspect the u-joints before replacing the transmission.
First on my list, thx for remonder, always to skip step one
Discussion Starter #4
Checked , not u joints, changed transmission oil, dropped pan very clean
When you checked the U-joints was that with the driveshaft removed from the truck?
Discussion Starter #6
Shaft on
Then you have no idea if the u-joints are good or bad.
Discussion Starter #8
Figured as much, i will pull shaft. Any guess on lifespan? After 180k is it a maintance issue at this point to replace?
At 180k, I would expect your u-joints have had a good long life. :)
Not a butt in but what’s the best way to check u joints with the shaft out of the truck?
With the shaft out of the truck move the joints and see if they move freely. If they have slack or a grinding noise or feel, they need to be replaced.
Discussion Starter #12
Have not forgot, next on my list to bring in to driveline specialist and replace
Discussion Starter #13
Finally replaced all u joints and carrier bearing, balanced shaft so will see what it does, in my mind still moving towards a new trans in next few months anyway. Hate to cut its life short but would rather replace before it leaves my stranded, also mot trans are 30 days out from build to delivery
Discussion Starter #14
I stand corrected, crawled under neeath and the rear were replaced, not sure if ront wear at a different rate, always assume both spinn all the time
1 - 14 of 14 Posts
