Ok so after looking at todays posts alone I feel like we are all having somewhat similar issues but I still feel mine is alittle different.
Heres the problem, when I start my truck, warm or cold, its chugs for a couple of seconds, like it wants to die if i don't touch the gas at all, in the neighborhood of 400 to 600 rpm. it flutters between that range for this time frame, and then it idles like its fine. I've been letting it warm up for a couple minutes and then drive on it easy till in normal temp range and I have no proformance issues that are thowing any flags up. I did feel it surge in rpm like twice in the last 3 weeks its been doing this but it was still cold and Im not sure if maybe I slipped and hit the gas alittle harder.
Heres the history. I don't drive it much now, and I had alot of trouble starting it recently in the cold weather, tristate area of NY. I decided to replace all the glowplugs, the valve cover harnesses, and the glow plug relay, due to the fact it has 196,000 and its been in florida the past few years. at this time b/c i was diving in to get under the valve covers I decided to change the intercooler to a banks intercooler system. at the same time I wanted to also start the head modifications for my veggie system I am getting ready to install. I thought I'd kill a couple birds with one stone, but now that I'm having issues, its making it very hard to pinpoint what is causing the issue.
I was able to change all 8 glow plugs, both harnesses under the valve covers, and the Glow plug relay.
I changed the intercooler, the boost tubes and the manifold infront of the turbo.
I did not get all of my veggie prep done though. I removed the passengerside fuel supply to the head, just under the downpipe/turbo outlet connection. I installed a checkvalve into the head and reinstalled the fuel line to the checkvalve. I had to bend the fuel line a little to line up properly, which concerned me that maybe I decreased the flow by making the radius too small, but i think i'm just being paranoid.
Then I went to install an adapter and 90 fitting in the plug on the driver's side rear head, and ran into a clearance issue with the exhaust manifold, so i reinstalled the plug and called it a day.
those are all the modifications I make in the two day install.
when i started the truck at the shop to drive home, i noticed nothing different at start up. I did notice that my boost gauge was only getting to 15 psi at full throttle where it was getting 23psi before this install. I think the gasket between the turbo and boost tube may not be sealing properly, any other ideas? I did remove the vacum line from the wastegate actuator, and i still only reached 16 psi...
So the real issue, the chugging at start up... if i give it gas for a second when i start up it obviously revs high, and then when it settles it idles normal. it only chugs if i start it and don't touch anything. But it actually starts now first try in the cold, which it hasn't done all winter. and further more there is no smoke at start up. before I changed all this out i was getting lots of whitish smoke, and it took many tries to get it running. I feel like the back pressure valve made more noise when it was warming up prior to everything i did, but i might just be making that up, i still do hear it when i'm driving and its warming up. by the way i have a 4" downpipe to a straight 5" into 6" stacks in the bed, so its loud anyway.
I am very good at my service intervals, oil at 3000, and fuel filter every two oil changes, which i know is too frequent, but i believe it is cheap insurance. so i thought i would change the fuel filter to see if it made a difference. when i removed the filter the prescreen in the cap was fully brown, I'm assuming rust of some sort??? I don't know if this is my issue or not. I have run maybe 50 miles on the new filter and I might take it out this weekend and see if its filled up again.
I don't know if this is a coincedence or is a result of something I changed. does anyone out there have any ideas, or has anyone seen this before? Thanks in advance for the help.
