1 - 12 of 12 Posts
You would love it! You have the opportunity to get all the needed parts for a change over from auto too.
where is it at and how much?
It is a ZF-5 transmission.
They come in two flavors, 2-wheel drive and 4-wheel drive, they can not be interchanged without an extreme amount of work. So you will need to get the correct version for your truck.
The S5-42 was the first of these; there are two subvariants: wide-ratio and close-ratio. The wide-ratio version was available in the years 1987-97, while the close-ratio version was only available on the later 7.3 engines of 1994-97. The S5-42 was then replaced by the S5-47 for 1998.
~Ben
~Ben
A change in number can mean many things or nothing. From what I have always heard only the close ratio was used with the diesel bell-house for the 6.9 and the non-ps 7.3s. You still need to know if it is 4x4 or 4x2.
Per ZF's official description:
The S5-42 ZF transmission is available in both wide-ratio and close-ratio versions. The wide-ratio version is available for all F-Series vehicles over 8,500 lbs. GVW, all engines (6007), except F-Super Duty Commercial Stripped Chassis equipped with a diesel engine. The close-ratio version is available only in F-Series vehicles with a 7.3L diesel engine and a GVW over 8,500 lbs. The ratios are as follows:
CLOSE RATIO (7.3L DIESEL ONLY)
1st: 4.14:1
2nd: 2.37:1
3rd: 1.42:1
4th: 1.0:1
5th: 0.77:1
Reverse: -3.79:1
WIDE RATIO (GAS AND DIESEL)
1st: 5.72:1
2nd: 2.94:1
3rd: 1.61:1
4th: 1.0:1
5th: 0.76:1
Reverse: -5.24:1
~Ben (DieselTruckMan81)
Ben,
Have you ever seen a wide ratio mounted to a non-powerstroke diesel?
1 - 12 of 12 Posts
