1 - 20 of 37 Posts
Long day yesterday....dyno, then went to a test n tune sled pull to test out the new clutch.
A few week ago, Jody was out and we beat the sh!t out of it on the dyno, and blew the head gaskets (fire rings). So, we knew it was hurt, but ran it anyway.
On the dyno, it was a Mustang single eddy current, 18k resistance, but couldn't load it. The run was from 2300-3500. They said something about not getting a good reading (spun too fast?) so 2400 was all I had and only 70 PSI. Oh well. The 5 gallon catch can in the bed filled with coolant-nice job on that one VAB.
Here is the video
509?
Then we headed to the sled pull to test the clutch, knowing the motor has to come out. Make sure when you swap from an auto to 6 speed, you wire in the neutral safety switch so you can use 4 lo.... Only got one hook in 4 HI 1st, then the motor wouldn't crank again-its hydrolocked-rods are still in the block. Once we get the heads to hold on the new motor with the R&R's, we wont keep it at 100 psi, we'll turn it loose. The turbos on here are huge-98 Thumper on the atmosphere unit-the 106mm Thumper is on order-no NOS is on my truck btw....just too bad we didn't get it done in time for TS
Best compliment was "that a Cummins?"
"no"....
"INTL DT466?"....
"no"..."just a lowly old 7.3."
here is the video
4 hi
/ubbthreads/images/graemlins/smokin.gif /ubbthreads/images/graemlins/smokin.gif /ubbthreads/images/graemlins/smokin.gif
Yayy for twins!
Sounds like you need a new crew cheif /ubbthreads/images/graemlins/wink.gif
Any pictures of the twins your willing to share? Thanks
That was an awesome thing to see in person. Nothing like the sound of a HUGE turbo lit and feel of how hard it pulls!
The motor is on its way out today, will be back together and ready to sling some dirt in Indy!
BB wasn't that slead a bit over weight. I heard something like 40K. Feel sorry for the guys you run agains in INDY. I'll be thrashing on mine that weekend to get gready for BTS. /ubbthreads/images/graemlins/wink.gif
Congrats BB...wish that video wasn't so short. I want to see more!
I like to see more too..... /ubbthreads/images/graemlins/smokin.gif
Looking good from FKP#1:)
Here is the video
509?
"no"....
"INTL DT466?"....
here is the video
4 hi
ONLY 70 psi??......Dang .....I thought you was boostin it.....lol
Good job!
Yall work out all the bugs in your setup , then sell it in kit form. /ubbthreads/images/graemlins/grin.gif. For cheap. I'll take two. /ubbthreads/images/graemlins/smokin.gif
Wowee do those things sound sweeeet! /ubbthreads/images/graemlins/smokin.gif
Sure looks like the clutch is hooking good and hard, too.
Discussion Starter · #20 ·
Good job!
Well, not sure where the bugs are-guess they would be in the motor build up-but that has now been rectified.
FYI-both head gaskets were blown. Pistons are good-no cracks, no valve contact, no drama. We also made 539 HP!
1 - 20 of 37 Posts
