since the center section is welded to the tubes and inner knuckles, then...
You could keep your outer shafts, knuckles, ball joints, brakes, hubs and hose barb for the esof.
You would need :
A new center section. bearings (new seals, as you don't want to reuse them), new inner shafts, carrier of your choice and ring/pinion.
It's probably better to just sell it as an assmebly (the 50) and get a 60.
