So ive been through a few issues with pan leaks. After a new pan and gasket i had to helicoil some threads. So now its all good except where the threads were replaced due to the hole being bigger. Any ideas on how to fix the new issue? Thanks
Its leaking around the holes you Helicoiled?
Yes. I would assume that drilling out the holes was just enough so the factory gasket leaks a very little bit.
Clean it thoroughly with brake clean and use a little silicone around those holes. Wait 24 hours before filling the trans so it fully sets and you should be good to go.
