Hey guys, I’m new here and having issues with my truck. I believe all the details of it should be in my signature if I did that correctly. Regardless, I was pulling my 40’ fifth wheel 300 miles this weekend through Kentucky. On the way down everything operated perfectly. We headed back after 2 days and the truck sat the whole time. We began descending down the highway that’s is winding and steep in spots. I had the truck in tow haul and it would sometimes downshift very harshly. I thought maybe being in towhaul and descending while on and off the brakes and on and off the accelerator may have made the trans confused. I parked at a gas station and before hitting the interstate. Everything was ok, trans temp was good and there was no fluid leaking nor any lights on. Once I hit the the interstate the truck gained speed and the trans shifted extremely hard into 5th with no rpm flair. I continued on after that because the truck seemed to be continuing along ok. I noticed the transmission wouldn’t shift out of 5th and into 6th (od). I then checked my temperature and saw it was on the rise at 240 and climbing. I thought maybe something was going on with the sensor because this trans has never ran hot. I continued until it got to 300 just before I was able to get to a safe place to pull over. I found 2 on bolts missing and fluid under the truck.
At that point I check fluid and saw none on the stick so I shut the truck off worried that I had lost a lot of fluid. After finding 2 bolts locally and fluid, the trans took 2.5 qrts to get back to full. I removed the battery cables and reset the KAM trying to get the trans to relearn. After reapplying voltage to the truck, I tried to start it and found that the key would not engage the starter. I jumped the starter relay and got the truck to start and noticed the monitor showing that 5th gear was commanded and the truck is idling high. I checked for codes and had numerous codes for transmission temps and range issues I believe it said. I didn’t record the codes yet unfortunately but I also had a fan clutch code. I’m wondering if maybe the fan clutch is causing things to go haywire somehow. Also when the truck is idling in park the transmission temp slowly continues to climb. Any insight would be very appreciated! Also the ambient was 25f-30f.
Thanks in advance!
edit: the truck is a 2007 f350 CCLB dually 6.0 that just had the modified epc and ddc solenoids changed as well as fluid and 6.4 pan and filter. 120k miles on truck. No power adders except a towing tune
Thanks in advance!
