Hey guys,
Torched is a mechanic company based in Hawaii. We zero in on Fab work, performance and repairs. We are pretty new to these forums and we are a pretty young company as well, but bare with us:
These two tips will help shut your check engine light off if you've altered the egr.
If you pull your egr sensor wire out to delete just the sensor and opperating system, 'you need to buy a tuner'. That is the most common way to turn your light off, in this instance.
If you went a head and did an egr delete (recommended way) and you get a check engine light. Do not leave your egr connector unplugged. 'Plug your egr sensor back in!!!' That will shut 'off' your Check Engine light. Even with a deleted egr, your truck will run normally without the egr actually operating. Plig it in!!!
