is it possible to to an 06 in an 04 spot had nothing but problems out of the earlier 6.0s. thanks in advance
Yes you can but it requires some modifications. Depending if your 04 has front leaf springs the lower rad hose connection is in a different spot on new motors due to them using coil springs. The icp sensor may need to have its harness modified. I believe it would be easy to swap front covers between the motors to accommodate the water outlet or you can modify the existing lower rad hose with a piece of pipe and hose clamps. The newer motors are quieter with the better high pressure pump and noise dampening oil rails on the injector.
