I've seen alot of posts talking about the 6.0 trans cooler and how they like it. Is it a direct bolt on or does it need to be tweeked to replace the OEM unit? What is the price of one?
The trans cooler from a 6.0 will fit in the place of your stock cooler, the lines from the 6.0 cooler are 1/2 inch and the stock lines are 3/8 inch. That is the tweaking that will need to be done, I got all of the fittings from a local hydraulic supply store to make the connections and about 6 ft of oil rated hose. Wear long sleeve shirt as getting in behind the a/c condenser will cut and scratch you up. just take your time, enjoy a few cold ones during the process. If you tow heavy it will be one of the best things you do for the life of your trans. Here in Vegas it gets pretty hot during the summer and with mine towing the trailer in my sig. I have not seen temps over 200 pulling some steep grades.
