I have a 2006 F250 crew cab 4x4 with 110,000 miles on it.
My mechanic confirmed I have a bed plate leak. He put UV die in the oil, cleaned the whole motor and let it run over a two day period and I have a small seep coming from the bed plate.
I have been reading up on this allot, and the consensus seems to be, it's not a big a deal. As long as its a small leak and is not hampering performance. I am inclined to agree with this. Very extensive (and expensive) repair for such a minor problem.
Here is my concern-
This summer I will be pulling our 6,000 lb camper cross country on a 3000 mile (4 week) road trip. I was wondering if the added stress of pulling a load for that long of a period would cause me problems.From what I have read, this bed plate could be a bad gasket. Or, it could be machined incorrectly from the factory. I'm not sure if towing will worsen the leak.
I don't want to spend big bucks unless it's necessary, if I do fix the leak, I will go ahead and put head studs, and what ever else will be good to replace, since the engine will be out and everything is easy to get to.
The last thing I want to do is break down 1,000 miles from home with a trailer that needs to be towed back.
But I also can't spend that much money unless it absolutely necessary.
Thank you All Opinions and Info !! :grin2:
Here is my concern-
