Hey everyone so I was having a problem with my 6.0. Every time the truck would shut off for a hour, I would start it and it would misfire. No code but would shake horribly. If I started to drive and gave wot for a second or 2 it would go away. Eventually it got stuck pretty bad one day and threw a code for #3. Buzz tested to confirm and no click. Got the money to have them sent to Holders diesel, where they bumped them up from 175/30 to 205/30. They also checked all injectors for issues and I labeled all of them and #3 had a bad solenoid which was replaced. Put them in and problem solved.. for 2 days. 2 days later code for #7 now with same symptoms, except it only misses for a few seconds at idle on startup and then goes away without having to give it throttle. Buzz tested and won't click when cold, clicks when warm. My question is what makes this happen and is it another solenoid?
