hello i have a 05 6.0 75k miles it starts fine cold but doesn't have full power when engine gets hot I hook my IDS up and it seems to have high pressure oil leak did some research everyone was saying stc fitting so I pulled it down and the stc fitting seems to be fine not saying its not leaking but im changing it to the updated one either way would yall rule the ipr out it seems to be working fine commanding 84% when hot cranking trying to build the oil pressure it was only building to 287psi when hot any other ideas yall have before I put it back together thank you
The other culprit is stand pipes and dummy plugs on the oil rails. You can pull them up on youtube.
Passenger side dummy plug was where my leak was.
