Pulled DPF off and added a new delete pipe. Started to check for leaks it was good and shut it off. Went to start again and will not start. I have a Mini Maxx tuner on the way. Does anybody know if it will start after I do a DPF delete tune?
Well if I assume you removed the EGT sensors then that would explain the no-start condition. Part of having a "delete" tune is to overcome this.
