Is it possible to remove the passenger side exhaust manifold without pulling the cab? I have a bad sounding noise and narrowed it down to this broken bolt on the exhaust manifold. Looks like it is going to be a very hard job
Any good advise would help
hello it can be done but no fun at all and lots of things have to come off also some can be done thru the fender well get ready to learn new cuss words and also be prepared to have more break off and be extremely stuck I had to grind off a few at te head as they stripped off like butter and another tip is use a grabber socket right off the bat the style for rounded off bolts ..... the are TTY bolts and use once and throw away the rear studs to the up pipes are also very hard to get off you may want to consider a partial cab lift witch requires removing the bed so the cab can be lifted in the front but again lots of stuff to remove or relocate..... I have a few pictures of my project on one of my threads titled "replacing some parts at 191k" good luck bud
