i am rebuilding my 85 6.9 i have a fresh top end with new glowplug system and glow plugs, new injectors, timed the ip several times all timing is correct, new supply and return lines, but i still have a horrible time starting when cold. two to three cycles of th glowplugs is usually needed then when she starts she smokes white all of the time even when warm. i have no muffler on it now could that be part of the issue, not enough back pressure? i also have a pusher pump in the frame rail for fuel 4-6 psi. if i plug the truck in for 2 hrs she will fire right up, but still smokes white. iv got two 850cca batteries and a starter with the mitsubishi gear reduction kit in it. i am also positive i have no air in the fuel done several tests. any ideas? im stumped. its a ritch fuel smell not antifreze. my ip was recently tested by diesel injection service and they said it was fine. runs great just hard to start and verry smoky
