I wouldn't call it a dumb question; I'd call it a hasty question. /ubbthreads/images/graemlins/wink.gif
Do semis haul their loads in overdrive? /ubbthreads/images/graemlins/shocked.gif Heck, they try to climb hills in overdrive! /ubbthreads/images/graemlins/blush.gif
Towing with a diesel, especially a turbodiesel, is a new paradigm compared to gasoline engines. As you may know, diesel engines have a torque curve that reaches maximum value at a lower rpm. This may not be helpful until you think of torque in terms of horsepower per rpm. Then you can interpret the torque curve correctly - a diesel can have more horsepower available at lower rpm.
I know with a auto if you tow anything significant you need to take it out of over drive
[/ QUOTE ] This is the right thing to do with your Dodge Dakota, Chevy Astro Van, and F150.
with a 6 speed is it the same way?
[/ QUOTE ] No. Put it in overdrive. Put the hammer down. /ubbthreads/images/graemlins/cool.gif And smile and wave at those poor suckers towing with gas. /ubbthreads/images/graemlins/biggrin.gif
Don't use cruise control except on long, flat stretches. If you are climbing a hill, and your EGTs get above 1250 pre-turbo, or your rpms drop below 1800, downshift to 5th.
If you don't know what "lugging" sounds like, such that you can properly avoid it, slow down to 25 mph in overdrive, and push your accelerator past half-throttle. That's lugging. /ubbthreads/images/graemlins/smokin.gif Avoid it from now on. /ubbthreads/images/graemlins/grin.gif
And good luck! /ubbthreads/images/graemlins/smile.gif
