Hi! My 1983 MCI MC9 coach started using a gallon of coolant (which I figure is about a teaspoon a mile) about 8,000 miles ago. It does not seem to have gotten any worse during that time. The engine starts normally, does not leak any coolant while sitting for a month, and has clear, dark oil which goes down normally (about a gallon in 1200 miles). Fuel economy and horsepower do not seem to be affected much. There are never any green drops under the bus, and there is no visible green "goo" on the engine.
I am assuming that the coolant is leaving through the exhaust. It seems like the top suspects are (1): A leaking injector tube OR (2): a crack in the head between a water jacket and an exhaust port.
Someone has suggested I might want to try a block/head sealer (Like Bar's Leaks HG1). HG1 can be used in antifreeze, and contains carbon fibers. Does anyone have any advice on that? I wouldn't mind replacing a head, if I could figure out which one needs it. What else could it be? ? ?
Thanks for taking the time to help!
