Have 7.3 parts I need to sell to clean out garage.
engine block
2 engine front covers
bell housing
2 exhaust valves- (new) #1823452C1
2 sets UVC harness / gaskets
oil cooler / oil filter housing
oil pan
crankshaft
2 oil pickup tubes
set of main bearings (new)
set of wrist pin bushings (new)
8 injector oil deflectors with bolts
16 roller tappets with hold down brackets
2 set of main caps with bolts
32 head bolts stock
16 roller tappets
13 rocker arms with roller bearing and mount
2 rocker arms without bearing and mount
16 pushrods stock
cam gear with bolt
radiator degas bottle
7.3 slip yoke
set of forged connecting rods
crank gear
flywheel spacer
dipstick tube
crankshaft
1 set of heads (have rust from setting but can be cleaned and machined)
$425 for everything if you come pick up. My cell phone is 423-322-0234
engine block
bell housing
oil pan
crankshaft
2 oil pickup tubes
32 head bolts stock
16 roller tappets
16 pushrods stock
cam gear with bolt
7.3 slip yoke
crank gear
flywheel spacer
dipstick tube
crankshaft
