I got a 93 f250 7.3 idi running about 55 to 65 the temp is around R and if I get on it a little bit at stops it will get to M or A I never seen this before till it started warming up now about 65 degrees idk if gauge is a joke but I did put different bumper on this truck with no holes this time but wouldn’t think it would affect it that much got any ideas thanks
If you're running a turbocharged engine it very much can cause that, especially if the boost pressure is a little high. If the radiator is partly plugged it'll run hot, if there is too much fuel getting to the engine it'll run hot, or a combination of all or any of the above.
