1 - 20 of 21 Posts
Hi everyone! i am very new to this forum ( just signed up 2 minutes ago) . i am currently getting my 1991 Ford F-250 into tip top shape and i had a question, right now im 15 so i want to trick this truck out. if i straight piped it, what would be the pros and cons of doing this, also, i do not know if my truck would sound good, so i was wondering if anyone would have suggestions, also!, my truck does NOT have a turbo on it, it is bone stock. thank you
straight pipe will be loud without a turbo, possibly illegally loud. otherwise no drawbacks
if your truck does what you want then I suggest you leave it alone
if you need more power I suggest you get a turbo, but be sure you need it, it's a lot of money or a lot of work
Ok, thank you so much, my truck is most likely going to be a daily driver so i dont think i need a turbo.
Discussion Starter #4
Also i was wondering if there was anything i need to watch for on the 7.3 idi
yea man i have had several idi they r loud str8 piped but brings out the power. things to watch for inj o-rings they go occasionally keep a fuel filter in ur box or keep it changed regular and enjoy they r bullet proof
there is a coolant additive, you can buy coolant that comes with it or you can buy it separately. napa can sell you something, or go to a tractor store and ask for coolant with diesel cooling additive for a ford.
Just remember its not a hot rod straight pipes get you pulled over more trust me also I tend to stomp the throttle more just saying
Discussion Starter #9
also another question. my truck has been sitting for a good 3-4 years ( over that time i started up, but didnt drive it on the road). other than checking the fluids and replacing filters, is there anything i need to worry about?
If you know what your doing wheel bearings and u joints and all ball joints also coolant exchange
I have been pulled over twice for my turbo straight pipe for noise violations and I have 3" from the turbo back I would look at your local laws before you straight pipe it to see what the bylaws say about excessive noise from your truck.
Discussion Starter #12
Ok, again, thank you guys SO much
DO WHEEL BEARINGS. I am also a teenager with one of these trucks, a 1984 6.9 idi non turbo, straight piped, and i neglected to do simple maintanence for a long time such as wheel bearings, greasing ball joints, tie rods, etc, and i ended up stuck 6 hrs from home on a road trip with a siezed wheel bearing. had to get towed home, new hub and rotor, etc. just over $600 in the end. bought the bearings for the other side for 30 bucks and did it in about 2 hrs on the first try. Save yourself the trouble of towing, etc. also, mine is straight piped as well and i think in sounds great. 25k miles in a year and half all over new england and no trouble, just keep an eye out for cops and lay off the gas if you see one
Tried straight pipe on my 90 idi, made it 3 days before a found a muffler I could slip in there, Sounded like a nascar when I got on it.
I got a 7.3 and a few things I am uncertain about is the fuel pump I'll start and drive it for a hour and then u shut it off and it doesnt want to start unless u pour water on the fuel pump and I was wondering whays the best way to straight pipe and make it sound good
Start by replacing your IP. Having to pour water over it means it is wore out. Straight pipe? if you're going to do it, go all out. put dual stacks out behind the cab, and end them at just about window height, then you'll be sure to hear it.
6” Stainless stack through the bed and right behind the cab! Thats the way to impress everybody 😉
OP, have you thought about a Walker BTM for a good sound?
My 93 non-turbo came straight piped via the exhaust rotting just ahead of the muffler. Without a turbo, it sounds like any big block v8. I personally dont care for it. I'm also 40 and have my own business, so I need to keep that "professional image"
1 - 20 of 21 Posts
